Defining a UI Property for the Item
The last step is to assign the variable in the new Web template to the item. Then you enter a value for the variable. The value you enter is what displays in a configuration session.
For example, if you assigned the template to a relationship, you must define a UI property for each item in the relationship.
To define a UI Property for the item
- Click the Properties view tab.
- In the box displaying the contents of the customizable product, select the item on which you want to define the UI property.
- In Item Display Properties, add a new record and complete the necessary fields: - Name. Enter the name of the UI property variable. Do not include the period (.) that begins the name.
- Value. Enter the value you want to the variable to have for this item.
- Save the new record.
- Open the Item Display Properties menu and click Validate. - This starts a configuration session. Verify that the item names display correctly.
