Exclude Template
The Exclude template has the form:
[item or condition] excludes [item or condition]
The exclude constraint is mutual. For example, if Item A is present in the solution, Item B cannot be present. Conversely, if Item B is present, Item A cannot be present.
The excludes constraint is functionally equivalent to a Boolean ! (A AND B), that is, a NAND operator. In the following table, a T (true) means the item is present in the solution. An F (false) means it is not present or is excluded.
| A | B | A AND B | ! (A AND B) |
| T | F | False | True |
| F | T | False | True |
| F | F | False | True |
| T | T | True | False |
The truth table shows that an exclude constraint is always true except when both operands are present in the solution.
Use an exclude constraint to:
- Prevent technical configuration errors. For example, a computer operating system or software application may be incompatible with certain microprocessors.
- Prevent configurations that are undesirable or ineffective. For example, in a financial model, an exclude constraint could prevent adding a low quality bond fund to a retirement portfolio.
