Excluding Values in the Administration - Product Screen
You can specify in the Administration - Product screen that certain values are excluded based on the expression variables defined by Set Procedural Conditional Variable rules. You can do this using the property, CondExcl=exprVarName. The attribute values or products in the domain with this property are shown as excluded when exprVarName evaluates to true.
To exclude values based on Set Procedural Condition Variable rules
- Navigate to Administration - Product screen, then the Products Definitions view.
- In the Versions list, drill down on the Workspace version of the product.
- Click the Properties view tab.
- In the Properties list, add a new record and complete the necessary fields, as described in the following table.
| Field | Comments |
| Name | Enter CondExcl. |
| Value | Enter an expression variable. The attribute values or products in the domain with this property are shown as excluded when this variable evaluates to true. |
