Modify the Constraints View Applet
This task adds the Rule Spec field to the Cfg SWE Rule Manager Applet.
To modify the Constraints View applet
- With the SWE Rule Manager Applet highlighted, select Tools, Lock Project.
- Right click the highlighted applet record and select Edit Web Layout.
- In the window displaying the layout, right-click and select Preview from the pop-up menu.
- Click the Template icon and select the Applet List (Base/EditList) template. It is the default.
- In the Mode drop-down menu, select 3: Edit List.
- In the Controls/Columns window, click Rule Spec, and move it to the [field] beside the End date in the applet display.
- Click Save.
- Click OK to save your changes.
- Deliver the workspace.
