Reviewing the Siebel Configurator Script Log File
If a method within a script fails or the script contains syntax errors, you can obtain valuable diagnostic information by reviewing the script log.
To review the script log file
- Navigate to - \log\cfgscript.log. It is located in the Siebel installation directory.
- Open the file with a text editor.
- Locate the entries for the date and time the script ran.
