UnloadInstance Method
This method removes the existing configuration session from memory. It must be called after synchronizing the instance at the end of the configuration session.
Input Arguments
- ObjId. The unique identifier of the complex object header.
- RootId. The unique identifier of the complex object root.
- IntObjName. The name of the integration object that was used to load the instance.
Output Arguments
None.
