About Supported Security Products
To augment the security of your Siebel CRM deployment, Oracle has alliances with leading security providers. For information, visit the Oracle Partner Network Web site at
https://www.oracle.com/us/partnerships/index.html
Oracle also provides a suite of security products, some of which have been certified for use with Siebel CRM. For information on the Oracle Identity Management products, go to
https://www.oracle.com/middleware/identity-management/
For information about third-party products supported or validated for use with Siebel CRM, see the Certifications tab on My Oracle Support.
Note: For Siebel CRM, the system requirements and supported platform certifications are available
from the Certification tab on My Oracle Support.
