Arguments for Get Work Item Info Method
The following table lists the arguments for the Get Work Item Info method.
Argument Display Name And Data Type Argument Name Type Req’d Comment
Channel Type
(type: String)
MediaType
Output
Yes
The language-independent channel type
Channel Type Locale
(type: String)
MediaTypeLocale
Output
Yes
The language-dependent channel type locale
Description
(type: String)
Description
Output
Yes
Work item description
Driver Work Tracking ID
(type: String)
DriverWorkTrackID
Output
Yes
The tracking ID of this work item in driver scope
Icon File
(type: String)
IconFile
Output
Yes
Icon file of the driver profile that owns this work item. The icon is also specified in the CSS file.
Is Active State
(type: String)
IsActiveState
Output
Yes
Indicates if this work item is active
Is Data Contained Inside
(type: Number)
HasWorkData
Output
No
Indicates if this work item contains data inside
Is Inbound Item
(type: String)
IsInboundItem
Output
Yes
Indicates if this is an inbound work item
Parent Work Item ID
(type: String)
ParentWorkItemID
Output
Yes
ID of parent work item
Profile ID
(type: String)
ProfileID
Output
Yes
ID of driver profile that owns this work item
Profile Name
(type: String)
ProfileName
Output
Yes
Name of driver profile which owns this work item
Time In Queue
(type: String)
TimeInQueue
Output
Yes
Time this work item stays in the queue
View Bookmark
(type: String)
ViewBookmark
Output
Yes
View bookmark
Work Duration
(type: String)
WorkDuration
Output
Yes
Duration of work item
Work Item ID
(type: String)
WorkItemID
Input
Yes
Work item ID
Work Item Key
(type: String)
WorkItemKey
Output
Yes
Work item key
Work Item Not Exist
(type: Number)
WorkItemNotExist
Output
No
Work item does not exist
Work Object ID
(type: String)
WorkObjectID
Output
Yes
Object ID
Work Start Time
(type: String)
WorkStartTime
Output
Yes
Time work item started
Work State
(type: String)
WorkState
Output
Yes
Work item state
Work Tracking Object Business Component
(type: String)
WorkTrackObjBusComp
Output
Yes
Name of business component for after-work tracking
Work Tracking Object Business Object
(type: String)
WorkTrackObjBusObj
Output
Yes
Name of business object for after-work tracking
