About System Environment Variables
Environment variables are variables configured for a particular computer hosting an aspect of a Siebel CRM deployment. These Siebel-specific environment variables configure interactions with the computer's operating system and various functions of Siebel CRM applications. Configure environment variables through the operating system of the individual computer. For information about configuring these variables, see Configuring System Environment Variables.
Environment variables configure a wide range of functionality and are covered in context-specific areas of the Siebel Bookshelf. The Siebel Bookshelf is available on Oracle Technology Network (OTN) and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location.
The following table provides a partial listing of environment variables for Siebel CRM or that affect the Siebel CRM applications, and it indicates one or more locations where each variable is documented. This list is not comprehensive. Some environment variables are set automatically. In general, you set environment variables explicitly only as you are instructed by documentation for Siebel CRM.
Where Documented
JAVA_HOME
Siebel Installation Guide
LANG
LC_ALL
LD_LIBRARY_PATH (Linux and Oracle Solaris)
LIBPATH (AIX)
NLS_DATE_FORMAT
NLS_LANG
NLS_SORT
ODBCINI
ORACLE_HOME
PATH
RESOLV_MULTI (Linux)
SHLIB_PATH (HP-UX)
SIEBEL_ASSERT_MODE
Siebel Performance Tuning Guide
SIEBEL_CODEPAGE
SIEBEL_CRASH_HANDLER
Siebel System Monitoring and Diagnostics Guide
SIEBEL_DATA_SOURCE
Using Siebel Tools
SIEBEL_DIAG_STORE
SIEBEL_ENTERPRISE
SIEBEL_FILE_ENCODING
Siebel Marketing User Guide
SIEBEL_GATEWAY_ROOT
SIEBEL_HOME
SIEBEL_LOG_ARCHIVES
SIEBEL_LOG_DIR
SIEBEL_LOG_EVENTS
SIEBEL_OSD_LATCH
SIEBEL_OSD_MAXLIMITS
SIEBEL_OSD_NLATCH
SIEBEL_OSD_PTHREAD_STACK_SIZE
2007183.1 (Article ID) on My Oracle Support
Note: This environment variable applies only to supported versions of UNIX or Linux operating systems.
SIEBEL_ROOT
SIEBEL_SARMBufferSize
SIEBEL_SARMFileSize
SIEBEL_SARMLevel
SIEBEL_SARMMaxFiles
SIEBEL_SARMPeriod
SIEBEL_SERVER_ROOT
SIEBEL_SESSMGR_TRACE
SIEBEL_SISNAPI_TRACE
SIEBEL_STDERROUT
SIEBEL_TABLE_OWNER
Using Siebel Tools
SIEBEL_UNIXUNICODE_DB
SPELLCHECKLEVEL1
Set to True when using the spell check feature with outbound email messages. For more information about this feature, see Siebel Email Administration Guide.
TEMP
TMP
TNS_ADMIN
USE_NEW_MM
USE_NEW_RM
