Effects of Different Definitions of Rules in Siebel Territory Management
The creation, modification, and expiration of rules depend on a number of factors:
Are the rules direct or indirect?
Is the alignment major, intermediate, or minor?
Is the Action flag set to Add or Drop?
Does an active rule already exist for the territory (although with different start and end dates)?
If an active rule already exists for the territory, is the activation date of the alignment before or after the effective start date of the current rule for the territory?
The following shows the effects of different definitions of rules.
| Rule Type | Alignment Type | Action | Defined in Alignment | Defined in Territory | Activation Date < Effective Start Date | Activation Date >= Effective Start Date |
Direct |
Major |
Add |
Yes |
No | New territory rule | New territory rule |
Yes |
Yes | New territory rule | No change to current territory rule | |||
No |
Yes | No change to current territory rule | Sets effective end date to the activation date for the current territory rule | |||
Drop |
Yes |
No | Drops not processed | Drops not processed | ||
Yes |
Yes | Drops not processed | Drops not processed | |||
No |
Minor or Inter-mediate |
Add |
Yes |
No | New territory rule | New territory rule | |
Yes |
No |
Yes | No change to current territory rule | No change to current territory rule | |||
Drop |
Yes |
No | Not applicable because there is no territory rule to drop | Not applicable because there is no territory rule to drop | ||
Yes |
No |
Indirect |
Major |
Add |
Yes |
Yes |
Yes | New territory rule | New territory rule | |||
No |
Drop |
Yes |
Yes |
No |
Add |
Yes |
Yes |
No |
Drop |
Yes |
Yes |
No |
