Roadmap for Using Siebel Territory Management
To use Siebel Territory Management, perform the following processes and tasks:
The Territory Management workflow in Life Sciences, illustrated in the following image, does the following:
  1. Set up divisions and positions.
  2. Set up territory hierarchy.
  3. Set up territory nodes.
  4. Set up the alignment (rules and conditions)
  5. Run the alignment.
  6. Review the alignment. Are the test results OK?
    • If No, return to Step 4.
    • If Yes, continue to Step 7.
  7. Activate/schedule the alignment (roll out)
  8. Review the territories and their rules.
  9. (Weekly) Maintain the alignment.
    Note: Setting up the alignment (rules and conditions) should be revisited on a quarterly or semi-annual basis.
Roadmap for Territory Management in Life Sciences.
The following illustrates the workflow of Territory Management in Consumer Goods.
Roadmap for Territory Management (Consumer Goods). In this image, the worfklow is divided into three sections: Setting Up Territories, Creating Objectives, and Visit Planning. Setting Up Territories consists of the following: Create Territories, Define Accounts, Define “Position”/Role/Category sets, Apply Territory (This adds people to Acc’t Teams). Creating Objectives has the following: Create Objective, Create Activities (add roles and categories), Associate accounts to the Objective, Apply (Create Activities for Each Acc’t) Setting Up Territories and Creating Objectives are connected to Visit Planning. Visit Planning has the following: Create Visit for an Account, Add Activities, Schedule the Activities.
Button Code Available Comments
Apply
HORZ
SIA
Will also work in HORZ if exposed in UI
Apply All
HORZ
SIA
Assign Activities
SIA
SIA
Will work only in SIA
Remove Activities
SIA
SIA
Apply Multiple Categories
SIA
SIA
