Siebel Territory Management Records Suitable for Bulk Loading
The following information lists the types records that you are most likely to want to bulk load into Siebel Territory Management using Siebel Enterprise Integration Manager.
| Record Type | Location on the Siebel Territory Management Screen |
Territories |
Territories List view |
Territory nodes |
Hierarchies List, Territory Nodes view |
Rules |
Alignments List, Rules view, Accounts, Contacts, Assets, Postal Codes, and Geo Zones subviews |
Conditions |
Alignments List, Conditions view |
