Setting Up and Configuring the Siebel Test Execution Plugin
The Jenkins custom plugin allows the user to interact with Siebel Master Server. The following procedure shows how to setup and configure the Siebel Test Execution plugin. The prerequisites for this procedure are:
  • Before installing the Siebel Test Execution (STE) plugin, you must set up the proxy server configuration.
    The STE.hpi plugin is available in the following location: SIEBEL_SERVER_ROOT/plugins.
To set up the proxy server configuration
  1. Navigate to Manage Jenkins, then Manage Plugins and select the Advanced tab.
  2. Add the following HTTP proxy server configuration settings:
    • Server: www.<your company proxy server>.com.
    • Port Number: <NN>.
    Note: Check with your IT administrator for the proxy settings.
To install the custom plugin
  1. From the Upload Plugin pane, navigate to the plugin location, select the STE plugin and then click Upload.
    The status of the STE plugin installation is displayed in the screen.
  2. Click Installed to check if the STE plugin has been installed successfully.
