Setting Up the Automation Adapter
Before you get started with the task of recording a functional flow, you must complete the procedures in this topic to set up the system preferences and profile configuration parameters for Usage Pattern Tracking. You must also delete UPT action sets, runtime events and system preferences.
To set the system preferences for Usage Pattern Tracking
  1. Navigate to the Administration - Application screen, then the System Preferences view.
  2. Set the system preferences as shown in the following table:
    Name Value
    Enable UPT
    True
    Enable UPT Context
    True
    UPTMax Record Cache
    100
  3. To implement the system preferences, you must restart the Siebel Gateway and Siebel Services.
To set the profile configuration parameters for Usage Pattern Tracking
  1. Navigate to the Administration - Server Configuration screen, then the Enterprises view.
  2. In the Enterprises Server applet, select the enterprise server you want to configure.
  3. Click the Profile Configuration tab. Query for the profile AutomationSubSys.
    Name Alias Datatype Value
    Class Path
    CLASSPATH
    String
    N/A
    Container URL
    CONTAINERURL
    String
    The value for the jbs. For example: CONTAINERURL=http://localhost:<ContainerPort>/siebel/jbs
    The <ContainerPort> value should be taken from the following: <Siebel_Install_Location>\ses\applicationcontainer_external\conf\server.xml<Connector port="4730" protocol="HTTP/1.1"
    For Example: http://localhost:4730/siebel/jbs.
  4. To implement the profile configuration changes, you must restart the Siebel Gateway and Siebel Services.
To configure the AutomationSubSys profile via the server manager command
  • Enter the following server manager command to configure the profile for AutomationSubSys:
    change param CONTAINERURL=http://localhost:<ContainerPort>/siebel/jbs for named subsystem AutomationSubSys
    The following table lists the runtime events configured out of the box.
    Sequence Object Type Event Action Set Name Conditional Expression
    2
    Application
    ViewActivated
    KWD
    GetProfileAttr("Enable Recording") = "True" AND GetProfileAttr("RecordingOn") = "True"
    2
    Application
    ViewDeactivated
    KWD
    2
    Application
    WebLogin
    KWD
    2
    Application
    WebLogout
    KWD
    2
    Applet
    PreInvokeMethod
    KWD
    2
    Application
    Recording
    KWD
    2
    Application
    InvokeServiceMethod
    KWD
    2
    Application
    UPTClientScript
    KWD
    GetProfileAttr("EnableRecording") = "True" AND GetProfileAttr("RecordingOn") = "True"
    2
    Application
    InvokeMethod
    KWD
Note: Any other UPT Events should be disabled or inactivated before using the UPT feature. Refer to the UPT documentation for Event Details.
Note: If 18.9 UPT enhancements are applied via Repository Upgrade, refer to Siebel Applications Administration Guide for UPT enhancements.
To delete UPT action sets, runtime events and system preferences
  1. To delete events set to UPT:
    • Navigate to the Administration - Runtime Events screen, then the Events view.
    • Delete all the Events with Action Set Name set to UPT: 'Action Set Name' = UPT.
    • Click Applet Menu and then click Reload Runtime Events.
  2. To delete action sets set to UPT:
    • Navigate to the Administration - Runtime Events screen, then the Action Sets view.
  3. To delete UPT system preferences:
    • Navigate to the Administration Application screen, then the System Preferences view.
    • Delete the following system preferences: UPTEEE1, UPTEEE2, and UPTEndToEndEventList.
  4. For changes to take effect, log out of the application and then back in again.
    Restart Enterprise Server for system preference changes to take effect.
