Testing Automation on a Android Device
To check the automation testing on a real device, you must connect the device (For example, Samsung Galaxy Tab) to the Windows 7 /10 machine with a USB cable.
Before running automation testing on a real device, make sure that WiFi and VPN connections are up and running.
To run automation testing on a real device
  1. Start your Android device.
  2. Tap Settings, and then General About Device.
  3. Tap the Build number seven times to enable Developer option.
  4. Return to the Settings menu and select Developer option.
  5. Tap the Developer options to turn on USB Debugging from the menu on the next screen.
