Identifying IBM DB2 Long Columns for Truncation in a Siebel Upgrade
Environments: Development, Test and Production.
Databases: IBM DB2 only.
In Siebel CRM version 7.7, the maximum length for IBM DB2 long
columns with a type of varchar was reduced to 16,350 from 16,383.
Upgrading from version 7.5.3 truncates long varchar columns that exceed
16,350. To prevent a data truncation error that might cause transaction
processing (txnproc) or transaction routing (txnroute) to fail, perform the steps in this task to identify
these columns and reduce the data in these columns.
data truncated error occurs, and transaction
processing and transaction routing might fail. To identify and reduce the length of long varchar columns
From any shell, open the script
chk16350.bat(Windows) orchk16350.ksh(UNIX), and edit the following parameters as appropriate for your deployment:SRC_USRis the username of the source databaseSRC_PSWDis the password for the source databaseSRC_TBLOis the tableowner of the source databaseSRC_TBLO_PSWDis the tableowner password for the source databaseSRC_ODBCis the ODBC data source name of the source database (edit the valueCHANGE_ME)SRC_REPOSITORY_NAMEis the repository name of the source databaseDBSRVR_ROOTis the directory where you installed the Siebel Database Server files on the Siebel Server, for example,C:\sba81\dbsrvr(Windows). Edit the valueCHANGE_ME.SIEBEL_ROOTis the directory where you installed the Siebel Server. For example,C:\sba81\siebsrvr(Windows). Edit the valueCHANGE_ME.VALID_RESULTS_DIRis the directory where you want the output files to be generated (edit the valueCHANGE_ME); this must be an existing directoryThis script produces two files:
long_trunc_cols.rpt. This report identifies all long varchar columns that are longer than 16,350 characters.
update_trunc.sql. This SQL file generates update statements that truncate identified columns to 16,350 characters.
Reduce the data in these columns using either of the following methods:
Manually review the columns in the
long_trunc_cols.rptreport and manually reduce the size of each column identified.Run
update_trunc.sqlusing the IBM DB2 command line processor.
