Running RepositoryUpgrade Utility
You can optionally run the RepositoryUpgrade utility on the development database to install new features since Siebel CRM 17.0 that require repository updates. This task does not apply if you do not require any of these new features.
For information about the new features that require repository updates, see Siebel CRM Update Guide and Release Notes on My Oracle Support for your Siebel CRM 22.x Update release.
The following procedure describes how to update the repository by running the RepositoryUpgrade
utility, which is located in the siebsrvr\bin folder.
$SIEBEL_HOME).To run RepositoryUpgrade utility
Run RepositoryUpgrade (RepositoryUpgrade.exe for Windows or RepositoryUpgrade.sh for other platforms) without any arguments to review the available command line arguments. The following tables describe the returned arguments and parameters, which you can use to run the RepositoryUpgrade utility.
Parameter
Description
Example
-sSiebsrvr installation path (Required)
C:\$SIEBEL_HOME\ses\siebsrvr-tSiebel Table Owner (Required)
SIEBEL-uTBLO Username (Required)
SIEBEL-pTBLO Password (Required)
********-oODBC Data Source (Required)
Siebel_DSN-dDatabase platform (one of: Oracle, MSSQL, DB2UDB, or DB2390)
Oracle-ySiebel Username (Required)
SADMIN-zSiebel User Password (Required)
********-rRepository Name (Default: "Siebel Repository") (Required)
Siebel Repository-gPrimary Base Language
ENU-wAdditional Languages (Default: None)
ARA,CHS,FIN,ITA-cSSE_ROLE (Required)
SSE_ROLE-mSeed inp (data input) creation for the Migration Application (Default: Siebel Log Directory)
Note: The RepositoryUpgrade utility will create a file named datamig.inp, which is required for the Migration Application to migrate seed data related to the repository changes from the DR to RR environment.C:\$SIEBEL_HOME\ses\siebsrvr\log-iUnicode DB (Default: Y)
Y-6Generate Schema File Only (Default: N)
Valid options are:
- Y (Yes, generate schema file only) – This option generates a file with the required schema changes without actually applying them. This allows your database administrator to apply the schema changes to the physical database outside of RepositoryUpgrade.
- A (Already applied Schema changes) – This option means schema changes are already applied. Use this option after the database administrator has completed the schema changes in the physical database.
- N (No, don't only generate schema file) – This option means that you run RepositoryUpgrade to perform schema changes and import all other changes in one execution.
Note: Use this switch to generate the required schema changes without actually applying them, thereby allowing your DBA to apply the schema changes outside of RepositoryUpgrade. For more information, see Independently Apply RepositoryUpgrade Schema Changes.N-9Parent Workspace Name
Note: Best practice is to specify an Integration Workspace reflecting a planned future release (you will receive an error if you specify "MAIN"). This will allow you to merge the Oracle changes with your custom changes and test them before migrating them to Production.<Parent_IWS_Name>-bDefault Tablespace
Note: Mandatory argument for Oracle, DB2 UDB, and DB2390 databases.SEBL_DATA-xDefault Indexspace
Note: Mandatory argument for Oracle and DB2 UDB databases.SEBL_INDX-k16K Page Tablespace
Note: Mandatory argument for DB2 UDB databases.TBLSPC16K-v32K Page Tablespace
Note: Mandatory argument for DB2 UDB databases.TBLSPC32K-4Provide a suffix for the log folder generated by RepositoryUpgrade. (Default:
Null)Example:
-4 Ora_23_11will cause the log folder to be created asRepositoryUpgrade_Ora_23_11-4 Ora_23_11The following arguments are required only for DB2390 databases:
Parameter
Description
Example
-24K Buffer Pool (Required)
BP1
-58K Buffer Pool (Required)
BP8K1
-f16K Buffer Pool (Required)
BP16K1
-732K Buffer Pool (Required)
BP32K1 -8Database Name Prefix (Required)
D + Last 3 Characters of your schema qualifier
-aDatabase Code Page (Required)
ASCII/EBCDIC/UNICODE
-jIndex Buffer Pool (Required)
BP2
-eStorage Group for Indexes (Required)
SYSDEFLT -hStorage Group for Tables (Required)
SYSDEFLT Note: Don't use parameters that are inappropriate for your database platform. For example, don't use the DB2390-jargument with Oracle, MSSQL, or DB2UDB databases. -
Execute the RepositoryUpgrade utility using values appropriate to your database. Examples for each supported database platform follow.
Oracle example:
RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t ORAXXXX -u ORAXXXX -p ******** -o Siebel _DSN -d ORACLE -y SADMIN -z ******** -b SEBL_DATA -x SEBL_INDX -c SSE_ROLE -9 int_1MSSQL example:
RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t dbo -u MSXXXX -p ******** -o Siebel_DSN -d MSSQL -y SADMIN -z ******** -c SSE_ROLE -9 int_1DB2 UDB example:
RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t SIEBEL -u SIEBEL -p ******** -o Siebel_DSN -d DB2UDB -y SADMIN -z ******** -b TBS_4K -x TBS_4K -k TBS_16K -v TBS_32K -c SSE_ROLE -9 int_1DB2390 example:
RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t CQ10D0XX -u QADMIN -p XXXXX -o Siebel_DSN -d DB2390 -y QADMIN -z XXXXX -c SSEROLE -b SIEBTS00 -2 BP1 -5 BP8K1 -f BP16K1 -7 BP32K1 -8 D003 -a ASCII -j BP2 -e SYSDEFLT -h SYSDEFLT -9 int_1 -
Review the returned output. Output similar to the following is expected:
------------------------------------------ Current Content Version : 21.3 Current DB Version : 19.12 ------------------------------------------ ------------------------------------------ Following builds available in the installer ------------------------------------------ 20.3 20.7 ... 21.3 ------------------------------------------ ------------------------------------------ Following builds need to be installed ------------------------------------------ 20.3 ... ... 21.3 ------------------------------------------ ------------------------------------------ Schema Installation Starts ------------------------------------------ Starting for each build Running for 20.3 ... Running for 21.1 Skipping: No Schema present for 21.2 Running for 21.3 Completed for each build Publishing Table Starts Sync Logical and Physical Schema Publishing Table Completed ------------------------------------------ Schema Installation Completed ------------------------------------------ ------------------------------------------ Repository Import Starts ------------------------------------------ Starting for each build Running for 20.3 ... Skipping: No Repository present for 21.2 Running for 21.3 Completed for each build Deliver Workspace Starts Deliver Workspace Completed ------------------------------------------ Repository Import Completed ------------------------------------------ ------------------------------------------ Seed Import Starts ------------------------------------------ Starting for each build Running for 20.3 ... Running for 21.2 Skipping: No Seed present for 21.3 Completed for each build Running Seed Copy for LOV for each branch ------------------------------------------ Seed Import Completed ------------------------------------------ ------------------------------------------ Manifest Import Starts ------------------------------------------ Starting for each build Running for 20.3 Skipping: No Manifest present for 20.7 Running for 20.8 Running for 20.9 Skipping: No Manifest present for 20.10 Skipping: No Manifest present for 20.11 Running for 20.12 Running for 21.1 Skipping: No Manifest present for 21.2 Skipping: No Manifest present for 21.3 Completed for each build ------------------------------------------ Manifest Import Completed ------------------------------------------ *** Integration Branch : int_siebel_update *** *** Workspace : dev_sadmin_siebel_21_3 *** *** Please review Web Tools -> Archive -> SIF Attribute Differences and resolve any conflicts. Once done, click Apply Changes to apply your decisions. If you do not make any changes in the report, all incoming configuration will be used. Once you checkpoint or version the Workspace, the Apply Changes option will be disabled. *** RepositoryUpgrade Execution Report Location : C:\$SIEBEL_HOME\ses\siebsrvr\log\RepositoryUpgrade_20210204_044026.htmlCheck the HTML file (RepositoryUpgrade Execution Report) for more details, resolve any issues, and then rerun the process if required.
At this point, RepositoryUpgrade will have created two new Workspaces in the repository, as follows:
An Integration Workspace named int_siebel_update_X directly underneath the Workspace specified by the
-9parameter (provided on the RepositoryUpgrade command line). -
A Developer Workspace under this Integration Workspace named "dev_sadmin_siebel_mm_dd", where mm_dd represents the release you are importing, such as 23.10.
The Developer Workspace was used to import the Repository changes. This Workspace can be used to inspect all the RepositoryUpgrade-supplied changes and resolve any conflicts before delivery to the parent Integration Workspace. For more information on this, review the section Viewing and Resolving Conflicts after Siebel Archive File Imports in Web Tools in the Using Siebel Tools guide.
After completing the conflict resolution, deliver the Developer Workspace to its parent Integration Workspace.
Rebase the int_siebel_update_X branch to its parent Integration Workspace and test it in conjunction with your customer changes.
- Once you are comfortable that your changes and the RepositoryUpgrade-supplied changes work
together, deliver the int_siebel_update_X branch to its parent Integration
Workspace.
Depending on your specific implementation and any conflicts that may exist, this process may require a Rebase, Conflict Resolution, Submission for Delivery, approvals in Siebel Approval Manager, and so on. For more information on delivering changes from a Workspace, see the Using Siebel Tools guide.
