About Reorganizing Tables Before the Repository Merge
Upgrades: All upgrades.
Environments: Development environment only.
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
During the repository merge process, objects from four separate repositories are read and compared. Because this is a memory-intensive process, it is recommended that you execute the REORG utility on certain tables before performing the repository merge to improve performance.
Note: Before executing the REORG utility, delete extra repositories from the database using Siebel Tools. Running the repository merge on a database with more than the four repositories which are required for the repository merge degrades repository merge performance. Before deleting extra repositories, make backups. Deletion of extra repositories can take a few hours.
The following tables receive a large number of inserts during each repository import; running REORGs on each of the following table’s ROW_ID column will significantly increase the performance of the merge:
  • S_APPLET
  • S_APPLET_INTL
  • S_APPLET_METH_MI
  • S_APPL_WEB_TMPL
  • S_APPL_WTMPL_IT
  • S_BOCOMP
  • S_BUSCOMP_UPROP
  • S_COLUMN
  • S_CONTROL
  • S_CONTROL_INTL
  • S_CONTROL_UPROP
  • S_DDOWN_OBJECT
  • S_EIM_FK_MAPCOL
  • S_FIELD
  • S_INDEX
  • S_INDEX_COLUMN
  • S_INTFLD_UPROP
  • S_INT_CKEY_FLD
  • S_INT_COMP
  • S_INT_FIELD
  • S_JOIN
  • S_JOIN_SPEC
  • S_LIST
  • S_LIST_COL_INTL
  • S_LIST_COLUMN
  • S_PICKMAP
  • S_SCREEN_VIEW
  • S_UK_ATTJOIN
  • S_USER_KEY_ATT
  • S_VIEW_WTMPL_IT
  • S_EIM_ATT_MAP
Note: After you reorganize tables, it is recommended that you run the RUNSTATS utility to update DB2 catalog statistics.
