Accessing the Target Database In-Place Upgrade Menu
The Target Database In-Place Upgrade Menu provides options that allow you to perform all of these tasks. Perform the following procedure to access this menu:
Access the Siebel In-Place Upgrade Main Menu by entering the following command:
EXEC ’DSNHLQ.SIEBEL.EXEC’
Select option 3: Target Database Processes - Upgrade, and press Enter.
The Target Database In-Place Upgrade Menu is displayed. The panel ID is SBLINPP.
