Authorization Requirements for Performing Upgrade Procedures on the z/OS Host
The user who performs upgrade procedures on the z/OS host requires the following authorities and access:
A thorough understanding of zSeries architecture, JCL, and TSO functions and navigation.
A TSO account with the authorization to allocate/create data sets on the z/OS host using the high-level qualifier specified in the FTP script.
Access to the DB2 staging and target system.
DB2 authorities to create DB2 objects and create DB2 VSAM data sets.
Grant and Bind authority.
DB2 Workload Manager refresh authority.
The default JOBCLASS is Q. Make sure you use the correct job class in the generated jobcards.
