Converting LONG VARCHAR Columns to CLOB Columns
Upgrades: Releases 7.5.3, 7.7.
Environments: All environments
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
In Siebel CRM Release 8.x and 7.8.x, the LONG VARCHAR columns of the following Siebel tables are converted to CLOB columns on z/OS to make sure data truncation problems do not occur:
S_BITMAP_DATA
S_DMND_CRTN_PRG
S_EVT_MAIL
S_NOTE
S_NOTE_ACCNT
S_NOTE_CON
S_NOTE_OPTY
S_SCHMST_DBSCPT
S_SCHMSTEP_SCPT
S_SERVICE_SCRPT
Before upgrading to Siebel CRM from a pre-7.8.x release of Siebel Business Applications, if any of these tables are already in 32 KB buffer pools, convert the LONG VARCHAR columns in these tables to CLOB data types to make sure the columns are not truncated if, for example, a column is added to the table during the upgrade.
