Creating and Loading Siebel Log Tables
Upgrades: All upgrades.
Environments: All environments
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
Perform the following procedure to create Siebel log tables and load them on the target database before you begin the target database upgrade.
To load the target log table
Use the following command to display the Siebel In-Place Upgrade Main Menu:
EXEC ’DSNHLQ.SIEBEL.EXEC’
Select option 2: Target Database Processes - Pre-Upgrade, and press Enter.
Select option 0: Create & Load Target Siebel Log, and press Enter.
Run the job using the JCL in data set
DSNHLQ.SIEBEL.INSTALL.JCL(LOADTAR)
.This loads the target Siebel log table using the
DSNHLQ.SIEBEL.JOBLOG.LOADFILE
.Verify that the job ran successfully with a return code of 0 or 4. For information, see Verifying JCL Upgrade Jobs.
After submitting the job, enter cancel on the command line or press PF3 to save changes.
