Exporting with the Migration Schema Service
You can export a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to export a resource:
  • URI: http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/Export
  • HTTP Method: POST
  • Content-Type: application/json
  • Authorization: Basic
  • Request parameter:
    • migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
  • Request body:
      "body":{
        "migrationid": "<Migration Id value>
The following are the details for the response to a successful request:
  • HTTP Code: 200
  • Response parameters:
    • trackingid: String that contains the tracking identification value.
  • Response body:
      "trackingid": "<tracking ID value>"
