Updating the Connection
You can update a connection for your migration by sending an HTTP PUT request to the Siebel Migration Application.
The following details are for a request to update a connection for a migration:
  • URI: https://{hostname}:{port}/siebel/v1.0/migration/connection/{connectionName}
  • HTTP Method: PUT
  • Content-Type: application/json
  • Authorization: Basic
  • Request Body:
       "name":"Demo Dev",
       "restEndpoint":"https://{hostname}:{port}/siebel/v1.0",
       "isFavourite":"true"
       "schemaUser": "",
       "tableSpaceData": "",
       "tableSpaceIndex": "",
       "tableSpacePage16K": "",
       "tableSpacePage32K": "",
       "isUnicodeDatabase": "true"
Note: You must include all attributes and attribute values (as required) in the JSON request body. If you omit an attribute, the attribute value for that property will be updated as empty.
The following are the details for the response to a successful request:
  • HTTP Code: 200
  • Response Body:
       "id":"88-1V5ZL2",
       "name":"Demo Dev",
       "restEndpoint":"https://slc04ovj.us.oracle.com:5021/siebel/v1.0",
       "isFavourite":"false",
       "schemaUser": "",
       "isUnicodeDatabase": "true",
       "resources":[
             "id":"88-1V5ZL3",
             "name":"Migration Schema Service",
             "displayName":"Schema Service",
             "type":"DB Util"
             "id":"88-1V5ZL5",
             "name":"Migration Runtime Repository Data Service",
             "displayName":"Runtime Repository Data Service",
             "type":"DB Util"
             "id":"88-1V5ZL6",
             "name":"Migration Application Workspace Data Service",
             "displayName":"Application Workspace Data Service",
             "type":"DB Util"
             "id":"88-1V5ZL7",
             "name":"Migration Incremental Runtime Repository Data Service",
             "displayName":"Incremental Runtime Repository Data Service",
             "type":"DB Util"
             "id":"88-1V5ZL8",
             "name":"Migration Incremental Application Workspace Data Service",
             "displayName":"Incremental Application Workspace Data Service",
             "type":"DB Util"
             "id":"88-1V5ZL9",
             "name":"Migration Application Data Service",
             "displayName":"Application Data Service",
             "type":"DB Util"
             "id":"88-1V5ZLA",
             "name":"Migration Application Data Service With Transformation",
             "displayName":"Application Data Service With Transformation",
             "type":"DB Util"
             "id":"88-1V5ZLB",
             "name":"MigrationFilePrepareAndDeploy",
             "displayName":"File Prepare And Deploy",
             "type":"DB Util"
             "id":"88-1V5ZLC",
             "name":"FINS BIB",
             "displayName":"FINS BIB",
             "type":"ADM"
