Removing Target Database Views
Perform the following procedure to remove views from the target database.
To remove views from the target database
On the Target Database In-Place Upgrade Menu, select option 5: Non-Additive Processes, and press Enter.
The following message appears:
Before proceeding, make sure ALL “Pret-FINS jobs completed. Re-enter option 5 to continue.
Reselect option 5: Non-Additive Processes, and press Enter.
The Target Database Non-Additive Processes menu appears. The panel ID is SBLNONP.
Select option 0: Drop Views, and press Enter.
Run the job using the JCL in data set
DSNHLQ.SIEBEL.INSTALL.JCL(SUBDRPV)
.Verify that the job ran successfully with a return code of 0 or 4. For information, see Verifying JCL Upgrade Jobs.
After submitting the job, enter cancel on the command line or press PF3 to save changes.
