Setting the RepVer Column Compatibility System Preference for DB2 Database
For DB2 database customers performing a Full Migration where the source environment is upgraded to 21.10 or later but the target environment is not upgraded, the import on the target environment will fail if the physical schema has not been migrated from the source to the target environment (something you would do if you want to manually apply the schema changes outside of RepositoryUpgrade). To avoid this import failure, add the RepVer Column Compatibility system preference to the source environment (if not already added) and set it to False.
RepVer Column Compatibility=False
