Reviewing the Extracted Storage Control File
After you have extracted the storage control file, you must carefully review and edit it to meet your requirements.
Note: If you extracted the storage control file on a Siebel Server that is on a UNIX operating system platform, and you would like to amend the file using the Siebel Database Storage Configurator utility (dbconf.xls), transfer the storage control file to a Microsoft Windows computer which has Microsoft Excel installed using a BINARY FTP file transfer mode. Using BINARY FTP transfer ensures that carriage returns in the storage control file are maintained and transferred correctly.
This task is a step in Process of Preparing the Storage Layout of the Schema.
To review the storage control file
  1. Navigate to the storage control file which is located in the directory that you specified when you ran the Database Configuration Wizard to extract the file.
  2. Check the following parameters in the control file and modify them as appropriate for your database.
    Note: Do not change the defaults for the following parameters in [Object 1] in the storage control file: IndexStogroup, IndexBp, PriQty, SecQty.
    [Object 1]
    Type = Defaults
    Name = Defaults
    Database = $DbnamePrefix0000
    Tablespace = SIEBTS00
    Stogroup = $StogroupTables
    IndexStogroup = $StogroupIndexes
    IndexBp = $IndexBufferPool
    Bufferpool = $4KBufferPool
    Locksize = Page
    SegSize = 32
    LockMax = 0
    PriQty = 48
    SecQty = 1440
    PctFree = 17
    FreePage = 0
    Compress = Yes
    Define = No
    Erase = No
    CCSID = $DbType
    [Object 2]
    Type = Database
    Name = $DbnamePrefix0000
    LockSize = Page
    [Object 3]
    Type = Tablespace
    Name = SIEBTS00
    LockSize = PAGE
    LockMax = 0
    SegSize = 32
    PriQty = 48
    SecQty = 1440
    PctFree = 17
    FreePage = 0
    Compress = No
    Partitions = 0
    Define = 0
    Erase = 0
  3. Once you have a storage layout that you are satisfied with, you are ready to continue with your upgrade.
    Every time you modify the storage control file, you must validate it again. For additional information, see Validating the Extracted Storage Control File.
Related Topic
