Setting Up File Prepare and Deploy
Siebel Migration File Prepare and Deploy service does the following:
Migrates file artifacts from the source environment to the target environment.
Migrates only file artifacts from Siebel Application Interface (AI) and the Siebel File System.
If the target environment has multiple Application Interface nodes, it migrates all file artifacts to all the Application Interface nodes.
Supports incremental file Migration (migrates only new or modified files).
Uses the Checksum utility to check whether the file is modified or not.
The list of directories considered for Migration are configured in the filemig_config.properties file. The filemig_config.properties file is located in the following directory:
<Application Interface Home>\applicationcontainer_external\webapps
The filemig_config.properties file:
Contains three properties:
inclusion-dir
exclude-dir
exclude-extension
Considers all the files from the list of directories provided in the inclusion-dir property.
Ignores all the directories mentioned in the exclude-dir from the include-dir only.
Ignores the files whose extensions are part of exclude-extension property
Sample filemig_config.properties file:
inclusion-dir=%ORACLE_HOME%/applicationcontainer_external/siebelwebroot/files, %FS_HOME%/att
exclude-dir=%ORACLE_HOME%/applicationcontainer_external/siebelwebroot/files/3rdParty exclude-extension=xps, pdf
Where:
%ORACLE_HOME%
is the AI installation directory.%FS_HOME%
is the Siebel File System Path.
You can add multiple directories separated by a comma.
