Skip Post Installation Database Update
If you do not want the installer to run the PostInstallDBSetup utility, then complete the steps in the following procedure. Post Installation Database Update is required in all situations except the following:
You are installing a new Siebel database instance that does not exist anywhere.
You have an existing instance of a pre-Siebel CRM 17.x version that you want to run an update or Incremental Repository Merge against after installing the binaries.
You have already run Post Installation Database Update during a previous Siebel Enterprise Component update for the same monthly update in the same enterprise.
To skip Post Installation Database Update
In the Siebel Enterprise Server installer for your monthly update release, select the Skip option to skip running the PostInstalDBSetup utility.
The installer will not run the PostInstallDBSetup utility.
