Target Tables Amended During PRET Processing
The PRET upgrade jobs perform operations on the target database tables listed in the following table. You might want to back up these tables before you start the upgrade.
The following table shows the target tables amended by PRET upgrade processing, the type of amendment made, and the upgrade path affected.
Tables Amended During PRET Processing | Type of Change Made | SIA Paths |
S_FN_CRDT_RPT |
Alter |
SIA753 |
S_REGION |
Alter |
SIA753 |
