Verifying If a Schema Changed with the Migration Schema Service
You can check if a schema for a Migration Schema resource has changed by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to check if a schema has changed for a resource:
  • URI: http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/IsSchemaChanged
  • HTTP Method: POST
  • Content-Type: application/json
  • Authorization: Basic
  • Request parameter:
    • watermark: Use the watermark parameter to enter the watermark value.
  • Request body:
    { "body":
        "watermark": "<watermark value>"
The following are the details for the response to a successful request:
  • HTTP Code: 200
  • Response parameters:
    • isschemachanged: Returns the value Y or N. Y indicated that the schema has changed. N indicates that the schema has not changed.
  • Response body:
      "isschemachanged": "Y"
