Extract from Catalog
This method extracts the storage layout of your existing database from the DB2 catalog; the output is a representation of the existing target database objects.
Use this option when creating the storage control file that is used to generate the DDL to build the staging database schema. For information on this task, see Required Tasks before Creating the Staging Database.
The Extract from Catalog method can also be used to perfect your target database layout by performing a dummy installation, manipulating the schema layout through native utilities, then extracting the customized layout. For information on the Extract from Catalog option, see Implementing Siebel Business Applications on DB2 for z/OS.
