Arguments for the SaveCartAsTemplate Method
The arguments for the SaveCartAsTemplate method are shown in the following table.
Name Type Data Type Optional Comments
Quote Name
Input
String
Y
Saves the Shopping Cart as a template with this name.
Quote Name Field
Input
String
Y
Tells the Shopping Service which field is the quote name.
By default, it is Name if this input argument is not used.
Return Error Code
Input
String
Y
If equal to N, the method will not return errors.
When a method returns an error, the workflow stops. To avoid stopping the workflow, you can set this input to N. This way, the Shopping Service will not return an error but instead save the error message in the output argument Error Message. You can then handle the error message as you want.
Error Message
Output
String
Y
Stores error messages.
ReturnVal
Output
String
Y
Returns Success or Fail. Not used.
