Authorize and Settle (AuthCharge)
CreditCard - AuthCharge (CyberSource Output). Its integration component is Invoice, as described in the following table.
Fields |
Fields |
CreditCard - Quote - AuthCharge (Siebel Input). Its integration component is Quote, as described in the following table.
Fields |
This integration object is not used out of the box. You can use CreditCard - Quote - Authorization (Siebel Input) for this method.
