Setting Up Read Auditing
You can configure Siebel Audit Trail to audit read operations on records.
This task is a step in Process of Configuring and Using Siebel Audit Trail.
To set up an audit trail of read operations
Navigate to the Administration - Audit Trail screen.
In the Audit Trail Buscomp list, create a new record for the business component, and complete the necessary fields.
Some fields are described in the table in Step 2 in Specifying Business Components and Business Component Fields for Audit.
In the Field view, create a new record, and complete the necessary fields.
Some of the fields are described in the following table.
Field Comments Field
Select the name of the field on which you want read-auditing.
Reading
Select this field to indicate you want read-auditing.
Click Update Audit Cache.
