Translating iHelp Items
When translating an iHelp Item, only the text strings that the user sees are translated. These text strings are:
Item name
Section labels
Step captions
Substep captions
If translation is not defined for a language, then the text from the base record appears.
This task is a step in Process of Administering iHelp.
To translate an iHelp item
Navigate to the Administration - iHelp screen, then the Translations view.
In the iHelp Items list, select an iHelp item.
In the Translations list, create a new record, and complete the necessary fields.
Some fields are described in the following table.
Field Comments Display Name
Type the display name for the translation of the iHelp item name
Navigate to the Designer view.
For each step, complete the following steps:
- Open the Translations folder.
Create a record to the Translations list and complete the necessary fields.
For each substep, complete the following steps:
- Open the Translations folder for the substep.
