Starting Workflow Monitor Agent for Dynamic Assignment Using the Server Manager Command-Line Interface
To run dynamic assignment, the Workflow Monitor Agent server component (WorkMon) needs to be running. This server component monitors the S_ESCL_REQ table. Database triggers, when fired because of object changes, create records in the S_ESCL_REQ table. The Workflow Monitor Agent reads these new records and processes requests for Assignment Manager policies. Affected objects are then dynamically assigned.
Complete the steps in the following procedure to start workflow monitor agent from the Server Manager command-line interface (srvrmgr). This task is a step in the Process of Running Dynamic Assignment.
To start Workflow Monitor Agent from the Server Manager command-line interface
Determine the workflow group that you want Workflow Monitor Agent to monitor.
Navigate to the Administration - Assignment screen, and then the Assignment Policies view.
In the Policy Group field in the Assignment Policies list, choose the workflow group (the default group is Assignment Group).
Start the srvrmgr program.
For detailed information on this task, see Siebel System Administration Guide. After the program starts, the prompt changes to:
srvrmgr: server_name>At the prompt, enter the following information to start the Workflow Monitor Agent server component task; use the Group information gathered from the previous step (Assignment Group used in this example):
start task for component workmon with GroupName="Assignment Group"Configure other component parameters, if needed.
For more information about other configurable parameters, see the following table.
Note: Separate the parameters and their values in the command-line statement with commas.Alternatively, you can configure a Workflow Monitor Agent to start automatically to process assignment requests whenever the Siebel Server starts.
For more information about Workflow Monitor Agent, see Siebel Business Process Framework: Workflow Guide.
This command starts a new task running in the background and returns to the Server Manager immediately.
The following table shows the Workflow Monitor Agent parameters.
Parameter Name |
Alias |
Description |
Default Value |
Action Interval |
ActionInterval |
Do not reexecute actions within specified interval in minutes. Note: This parameter applies only to workflow
policies, not to assignment policies. |
3600 |
Cache size of Policy violations |
CheckLogCacheSz |
Number of policy violations to store in cache |
100 |
Cache size of last user information |
LastUsrCacheSz |
Number of last user information items to cache |
100 |
Group Name |
GroupName |
Group Name |
Not applicable |
Ignore errors |
IgnoreError |
Ignore errors while processing requests |
FALSE |
Mail Server |
MailServer |
Name of email server to send notification of abnormal termination |
Not applicable |
Mailing Address |
MailTo |
Email address to review notification of abnormal termination |
Not applicable |
Number of days to keep violation information |
KeepLogDays |
Number of days worth of violation information that should be retained |
30 |
Number of seconds to retry |
GenReqRetry |
Number of seconds to retry sending a Generic Request message |
120 |
Processes the batch Policies |
BatchMode |
Process the batch policies |
FALSE |
Reload Policy |
ReloadPolicy |
Reload Policy Interval, in seconds |
600 |
Request delete size |
DeleteSize |
500 |
Requests per iteration |
Requests |
5000 |
Sleep Time |
SleepTime |
Time to sleep between iterations (in seconds), that is, is the frequency of time the Workflow Monitor Agent polls the S_ESCL_REQ table (escalation request table) and assigns rows. For example, if SleepTime is set to 60 seconds, then the Workflow Monitor Agent polls the S_ESCL_REQ table, then waits 60 seconds before it polls it again. |
60 |
Use Action Agent |
ActionAgent |
Use Action Agent |
FALSE |
For more information about starting, stopping, and monitoring server tasks, see Siebel System Administration Guide. For more information about the Workflow Monitor Agent, see Siebel Business Process Framework: Workflow Guide.
