Associating a Preventive Maintenance Plan with a Product
After you define the preventive maintenance plan triggers, use this procedure to associate it with a product you added. See Managing Products for more information on using Products.
This task is a step in Process of Setting Up Preventive Maintenance.
To associate a preventive maintenance plan with a product
  1. Navigate to the Preventive Maintenance screen, then the Preventive Maintenance List view.
  2. Select a preventive maintenance plan record.
  3. Click the Products view tab.
  4. In the Products list, add, edit, or delete records.
Related Topics
Setting a Trigger for a Preventive Maintenance Plan
Associating a Preventive Maintenance Plan with Vehicles
