Associating a Specification with a Product
Use this procedure to associate a specification with a product.
This task is a step in Adding Product Features and Specifications.
To associate a specification with a product
  1. Navigate to the Administration - Product screen, then the Products view.
  2. Select the product record that you want to associate a specification with.
  3. In the Administration - Product link bar, click the Specifications link.
  4. In the Specifications list, create a new record.
  5. In the Category field, select the category for the specification you just created in Working with Product Specifications.
  6. Complete the fields as necessary.
