Managing a Product’s Information
Use this procedure to view, edit, create, and delete a product. You can define product information about options, features, and specifications.
Note: The fields in the More Info view change according to what is chosen
in the Type field on the Product form.
This task is a step in Process of Managing Products.
To view, edit, create, and delete a product as a vehicle
Navigate to the Administration - Product screen.
In the Products form, add, edit, or delete records.
