How Siebel CRM Uses a Filter Business Component
A filter business component provides the group of records where Siebel CRM performs the context search. Siebel CRM uses the following logic to identify the records that it displays:
If the Is User Search Spec property is FALSE, then the user can only query records that Siebel CRM displays in the view. This is the default behavior.
If the Is User Search Spec property is TRUE, then the user can query all records. The Search Specification property determines the default records.
The following table describes example properties of a context search. In this example, the Is User Search Spec property is FALSE, so Siebel CRM displays only the records that include Opty as part of the name.
| Property | Value |
Name |
Type |
Expression Business Component |
Filter Business Component |
Search Specification |
Is User Search Spec |
