Using <MapArgs>
<MapArgs> is a runtime input argument used by the DTE map to match an integration map argument of an integration object map. The FINS ACORD XML DTE can take as many <MapArgs> as needed as long as each name is unique among all the <MapArgs> that are passed to the FINS ACORD XML DTE at the same time.
For example, suppose that the output integration object instance has some fields mapping to a workflow process property, such as an ID field.
Using the Data Map view, select the integration map to edit in the Integration Object Map applet.
In the Integration Map Argument applet, create the map and set the following values:
Name = CompId
Data Type = “DTYPE_TEXT”
Display Name = Component ID
In the Integration Field Map applet, set the following values:
Target Field Name = [Id]
Source Expression = [&CompId]
In the workflow, set the data transformation engine input argument as follows:
Input Argument = CompId
Type = Process Property
Property Name = Object Id
At runtime, the DTE replaces [&CompId] with the value of the Object ID.
For some mappings, if the DTE cannot find the source field value, the DTE creates empty tags by default. To remove the empty tags, add IgnoreEmptyTag as the map argument.
For complete information, see Business Processes and Rules: Siebel Enterprise Application Integration.
