Capturing a Reading for an Asset
For tasks such as taking a utility meter reading or measuring hydraulic pressure, you must record an asset reading.
To capture a reading for an asset
  1. Tap Side Menu and then tap Assets to display the following:
    • The Assets list in the main pane.
    • The Calendar showing the activity planning information in the side pane.
  2. In the Assets list, tap the link in the Asset # field to drill down on the selected record.
    All details for the selected asset appear in the main pane.
  3. Capture a new asset reading as follows:
    1. Under Readings, use the navigation arrows to move through the list of different readings that can be captured.
    2. Tap an individual reading, and then tap New (the plus (+) icon) to capture a new reading.
    3. Enter the information for the new reading in the fields that appear, and then save the record.
