Creating a 64-bit Java Subsystem by Using the Siebel Web Client
The following is an alternative procedure for creating a 64-bit Java subsystem by using the Siebel Web Client.
To create a 64-bit Java subsystem by using the Siebel Web Client
In the Siebel client, navigate to the Administration - Server Configuration screen, Enterprises view.
In the first list applet, select the Enterprise Server that you want to configure.
In the middle applet, click the Profile Configuration tab.
Click New to create a new component profile and set the following parameters:
Name Value Profile
JAVA64
Alias
JAVA64
Subsystem Type
JavaContainerSubSys
In the Profile Parameters list applet (the last applet), set the following values:
Set the Value of the JVM Classpath parameter to the following:
The location of the jndi.properties file (if using the JMS Transport).
Set CONTAINERURL to point to the java container. For example:
CONTAINERURL=http://localhost:<Config Agent HTTP Port>/siebel/jbs for named subsystem JAVA64Based on your usage, place all other JMS Provider jars in the lib directory of the Apache Tomcat server.
