Changing Configurations of Existing Products for Multi-Site Revisions
A multi-site revision inherits the field data for the configurations of the existing products in the source multi-site quote. You can change the configurations of the existing products for a multi-site quote revision when the customer changes the conditions for the services that are associated with those products.
Earlier multi-site revisions of a multi-site revision can include various configuration changes of products. The value that you select in the Effective Date field when you change the configurations of existing products affects these existing configuration changes as follows:
  • If you select an effective date that is later than the effective date for all the existing configuration changes, then your change is added to the sequence of existing configuration changes.
  • If you select an effective date that is earlier than the effective date for some existing configuration changes and later than the effective date for other existing configuration changes, then when you submit the multi-site quote, the following outcomes occur:
    • The existing configuration changes that have effective dates that are earlier than the effective date for your configuration change are retained.
    • The existing configuration changes that have effective dates that are later than the effective date for your configuration change are cancelled. A message alerts you of this situation when you enter a value in the Effective Date field for your configuration change. If necessary, you can add one or more of these cancelled configuration changes when you create additional multi-site quote revisions.
If you make configuration changes to a retired product, then the configuration changes cancel the retirement. If necessary, you can retire the product again in a revision of the multi-site revision.
This task is a step in Process of Creating Multi-Site Quote Revisions (End User).
To configure an existing product for a multi-site quote revision
  1. Navigate to the Multi-Site Quotes screen, then the List view.
  2. Drill down on the name of the multi-site quote.
    Check the revision number and version number of the quote to make sure that you open the correct quote.
  3. Click the Product Groups view tab, and select a record in the Product Groups list.
  4. Click Products in the link bar to navigate to the Products view, and select a record in the Products list.
    A product record for an existing service does not have a value of Add in the Action field.
  5. Configure the product by completing the following steps:
    1. Select the effective date of the configuration in the Effective Date field.
      Any value in the Retirement Date field is deleted. The effective date of the configuration must be the same as or later than the requested date for the multi-site quote revision, the same as or later than the inclusion date for the product record, and the same as or earlier than the retirement date, if any, for the product record.
    2. Click Customize to open Siebel Configurator and start a configuration session for the product record.
      The configuration session shows the configuration in effect on the effective date that you select.
      Note: The Customize button is enabled only for products that you can configure. The customize feature is available only if you licensed Siebel Configurator.
    3. Configure the product, and add, remove, and configure its components as necessary.
      You use Siebel Configurator in the same way that you use it when you configure the products for any quote or order in Siebel Business Applications. For more information, see Siebel Order Management Guide.
    4. Close the configuration session.
      If you do not configure the product, the value in the Action field for the product record changes to - (dash). You must also delete the value that you selected for the effective date of the configuration.
      If you configure the product, the value in the Action field for the product record changes to Update, and the value in the Action field for the applicable product attributes of the product record changes to the appropriate value.
