Setting Up Renewal for Agreements
Users can manually renew agreement line items by entering a current or previous day in the Start Date field and then clicking the Renewal button. For more information, see Renewing Line Items for Agreements (End User).
You can use workflows to automatically renew agreement line items. You can use the FS - Agreement Renewal Item workflow and the FS - Agreement Renewal All workflow to set up a repeating component job to automatically renew agreement line items for predefined time periods. For example, a workflow process can run daily to find any start dates equal to the current date, and then automatically renew the line items. For more information, see FS - Agreement Renewal Item Workflow and FS - Agreement Renewal All Workflow.
Renewal terms for an agreement line item follow:
Start date (required)
End date (required)
Price adjustments
Charge adjustments
Use plan
This task is a step in Roadmap for Administering Agreements.
To set up renewal for agreements
Navigate to the Administration - Server Management screen, then the Jobs view.
In the Jobs list, create a new Job record.
In the Component/Job field, select Workflow Process Manager.
Enter the appropriate Repeat Interval and Repeat Unit in the Job Detail view.
For example, a Repeat Unit of Weeks and a Repeat Interval of 1 runs the renewal process on a weekly basis.
Scroll down to the Job Parameters list, and create a new parameter record.
In the Name field, select Workflow Process Name, and in the Value field, enter FS - Agreement Renewal Item or FS - Agreement Renewal All.
Click Start in the Jobs list.
