Actual and Abbreviation Field 9
Use this user property to define the actual field and corresponding abbreviation in the Function Space Diary.
Actual and Abbreviation Field 9 | Description |
Value |
Function Status;Function Status Abbr |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets |
Usage |
The usage is the same as the Actual and Abbreviation Field 1 user property. |
