CanInvokeMethod: CopyRecord
Use this user property to disable the Copy Record functionality in Menu Administration, Event Order Item Administration, and Package & Specific Space Administration.
The user property for the TNT SHM FSI Sleeping Room List Applet applet, which is enabled in the Oracle’s Siebel CRM base application (the functionality that is common to Oracle’s Siebel Business Applications that are not industry-specific), is disabled in Siebel Hospitality to resolve a visibility issue.
Property Description/Value
Value
N
Parent Object Type
TNT Property Product Admin List Applet, TNT Package Administration List Applet, TNT Menu Administration List Applet, and TNT SHM FSI Sleeping Room List Applet applets
Usage
Due to some technical constraints in Administration - Product, you must disable the Copy Record functionality in Menus and Packages-related ad­ministration views in order to release a copied product.
