Copying Room Blocks
If necessary, you can copy room blocks. This can help when entering numerous room blocks for a quote. When you copy a room block, the room block details and existing line items are copied to the new room block.
This task is a step in Process of Managing Hospitality Event Inventory.
To copy a room block
  1. Navigate to the Quotes screen, then the List view.
  2. In the Quotes list, query for and select the required record.
  3. Click the link in the Name field, and then click the Room Blocks tab.
  4. In the Room Blocks list, select the required room block, and then click Copy.
    The new room block appears in the list.
