Creating Addresses for Properties
Before creating a property record, you must define an address for the property.
This task is a step in Roadmap for Setting Up Hospitality Properties.
To create an address for a property
Navigate to the Administration - Data screen, then the Zip Code Administration view.
In the Zip Code Administration list, enter valid data for all ZIP Codes.
If you do not have valid data for ZIP Codes, you will not be able to associate an address with a property. For more information about administering ZIP Codes, see Siebel Applications Administration Guide.
Navigate to the Administration - Data screen, then the Addresses view.
In the Addresses list, create an address record for each property, complete the fields, and save the record.
